RoyB
May 18, 2013Explorer III
Usually when the title reads SMOKED AT THE PEDESTAL there is actually smoke. After reading your description I don't know if you have had a failure at the PEDESTAL or not.
Sometimes the PEDSTAL has worn-out 120VAC contacts which causes your SHORE POWER PLUG to look something like this.
I suspect you have a converter/charger failure not a SHORE POWER CABLE failure caused by worn-out contacts in the camp ground pedestal.. However you need to determine if the 120VAC SHore Power from the PEDESTAL is good.
Here is simplified 120VAC 30AMP Wiring block diagram that might help
It sounds like your failed converter/charger unit has resulted in your on-board battery to become discharged. You will need to get that charged back up before internal battery damage is done to your battery. This internal battery destruction starts when a deep cycle battery is discharged below 12.0VDC which is close to being below the 50% STATE OF CHARGE.
Then you need to get a multimeter from LOWES-WALMART-Any number of auto parts stores ($10-#20) and start looking for reason for no charging capability with your on-board converter/charger when on shore power. The on-board converter should put out 13.6VDC all the time when connected to shore power power. Your first good clue is you will have bright ceiling lights inside your trailer. These lights will be dimmer if only running from the on-board battery.
let us know what is happening and provide model number of converter/charger unit. The more info the better...
Roy Ken
Roy Ken
Having RV issues? Connect with others who have been in your shoes.24,373 PostsLatest Activity: Apr 01, 2026
