time2roll
May 18, 2013Nomad
You said you plugged into 50a but is it a 50a or 30a RV?
I would be looking for a loose neutral connection that will cause unbalanced voltages. 30a RV it is in the pedestal or camp system. 50a RV I would try to trust he tested the pedestal correctly and you have an issue in the RV. I would start by taking the cover off the transfer switch and electric panel. Look for issues of heat on the neutral bus or neutral connection.
Having RV issues? Connect with others who have been in your shoes.24,373 PostsLatest Activity: Apr 01, 2026
