Bob_Shaw
Jul 08, 2016Explorer
I had an issue with my water heater after an extended period of non-use. The flames came out into the compartment rather than into the (I guess you'd call it) combustion chamber. Having seen this before I took the venture tube off and cleaned it of the spider web that was blocking the smooth flow of gas. It was almost invisible, but, I ran a stick down it, wiggled it around, and then when back together it worked great. Spiders and mud daubers are a real problem, and apparently attracted to, gas burners.
Having RV issues? Connect with others who have been in your shoes.24,412 PostsLatest Activity: Sep 13, 2026
