TechWriter
Aug 19, 2013Explorer
bob213 wrote:
If you have a fixed temp. (no outside controls--only fin slider) these work pretty well and bypass the thermistor cable.
thermistor adjuster
I used Dinosaur Adjustable Thermistor instead of the Snip-the-Tip only because I didn't want to cut anything, but both methods appear to work very well.
On my 12-year-old Dometic NDS1292, the fridge temp usually stays between 34-38 degrees instead of hovering around 40.
Having RV issues? Connect with others who have been in your shoes.24,401 PostsLatest Activity: Jul 25, 2026
