bob_nestor
Aug 20, 2013Explorer III
JC2 wrote:bob_nestor wrote:
I did a big engineering experiment on the Dometic RM2554 in my Roadtrek 210P last year trying to improve performance camping in hot weather here in Texas. I did fans, baffles and the Dinosaur control board replacement. I wrote up all my findings and posted them at:
Improving Dometic Refrigerator Cooling
Details of how to build the baffles and fan controls are also posted there along with the parts list and where the parts can be obtained.
-bob
In your opinion, do you feel the dinasour board would do a better job or this device which is also available from the same people?
http://www.dinosaurelectronics.com/Dom_adj.htm
I haven't played with it so I'm just making a guess here, but from the description the Dometic temp adjustment device is designed for fixed temp units, not variable temp units. My unit, the RM2554, is a variable temp with eyebrow controls, so this wouldn't be a good choice for me. The replacement Control Board I used was designed to totally replace the original Control Board with the added benefit that it contains an additional temp adjustment control. I can't find the reference right now, but I thought when I was doing this I'd found some articles or reports that indicated the Dinosaur Control Board is a bit more robust than the original Dometic board which may be another reason for using it.
I certainly got a lot of improvement using the Dinosaur Control Board, but I think I also gained a lot of performance improvements when I installed the re-engineered Dometic Innovator System. Getting proper airflow over the cooling coils is really important, and most RV manufacturers don't do a good job at that in their installations.
Hope this helps,
-bob
Having RV issues? Connect with others who have been in your shoes.24,401 PostsLatest Activity: Jul 25, 2026
