Thunder_Mountai's avatar
Thunder_Mountai
Explorer II
Mar 06, 2015
So, how long can house batteries last?
I have got to be running on borrowed time with my 4 6V house batteries. They were put in service in December of 2006. They've been kept charged via solar or shore power, never discharged, never allowed to run low on water and have had new cables.
Looked at new battery cost and had a bit of sticker shock. So how long can they last?
  • Bobbo's avatar
    Bobbo
    Explorer III
    Mine lasted 7 years, but for at least half of that time, I abused them with a single stage charger, and less than frequent water checks. When I finally did get around to checking the water, the pair of group 27 batteries never took less than 3/4 of a gallon, between them. I am really surprised that thay lasted that long.
    I upgraded to a 3 stage charger after 4 years. I finally replaced my batteries a couple of months ago with a pair of 6v golf cart batteries. I am vowing to check the water more frequently.
  • On normal flooded golf cart batteries, I figure 30~36 months
    But we full-time off grid, mostly dry camping
    Do that is around 1000 use cycles, charging..discharging
  • I'm currently running a couple T105s that are approaching 12 years old and still work well. They were 8 years old when I acquired them. I don't think they were ever really used before I got them, and I haven't strained them much either. They've spent most of their time in maintenance mode. I'm considering replacing them this year just because.
  • If you *never* boondock, and it doesn't sound like you do, you only need one 12v battery. I guess you could let those die of old age.
    A much bigger shock will be if they die on a camping trip and you're nowhere near a store.
  • I got 7 years 11 months out of 2 OEM T-105's
    Then got 7 years 3 months out of the replacement 2 T-105's
    Just put a PowerPulse on the 1 year 5 month old replacement T-105's.
    Will know in another 6 years if it helps or not.
  • 8 yrs no problem for 6 volts, been there.
    Not sure about 12'ers, but mine at near 5 yrs now, and looking good.
    My secret, a PD wizard conv/charger. Whatever they do, they do it right.
  • You state "never discharged" them :h
    What is your meaning by this? Do you not use them? Or are you saying you never let them get below a certain voltage?
    The number of draw down cycles will greatly effect the life of a battery.
  • One to ten years or even more. Depends mostly on how they are cared for.
    I figure minimum seven years for my use.
    Your 2006 batteries must be nearing the end.
  • The last time I purchased a marine battery for my camper was about 4 years ago. I bought it from Batteries Plus. The warranty, or guarantee on any of them was only 1 year. For over $100 a battery, I was REALLY disappointed. We sold that camper about 2 years after that. When we sold, the battery was still doing very well. The original battery that came with the camper lasted 6 years.
    So you know .... is anyone's guess these days!
Having RV issues? Connect with others who have been in your shoes.24,363 PostsLatest Activity: Mar 05, 2026
