Almot
Oct 02, 2017Explorer III
time2roll wrote:
{Li no floating} is a bit of a conundrum for solar as I don't know of any controller that fully disconnects. Honestly I believe if the float voltage is set well below the fully charged resting voltage the typical RV will have no issues.
I would trust what particular Li manual says.
Those Li battery/charger combos that I've seen, recommended shut down. Some are automated and allow charging to either 80% or 100% or an arbitrary point in between, based on voltage (and then it shuts down). BMS would only protect from overcharging and overheating, overcharging meaning running the current past 100%.
In storage the recommendations were to top it up every 2-3 months (though it wasn't clear - with a cheesy charger that came with the battery or with one of better models that allow 80%). None of them was for 12V though. I hear that in electrical cars it does limit to 75-80%, whether BMS or the charging circuits.
Cell phone - yes, you should not keep it on charger when charging is completed. This is what it reads on the screen of my phone - "charging completed, please disconnect" :) ... For protecting charger, if nothing else. Don't know how sophisticated its BMS is, and when exactly it reads "completed" - at 80, 100, or several minutes past 100%. The industry approach is to treat it as a disposable and very short-lasting item, I usually keep mine longer than they would like me to, but their thinking makes me wary as to the product features.
Having RV issues? Connect with others who have been in your shoes.24,374 PostsLatest Activity: Apr 08, 2026
