jlscjs's avatar
jlscjs
socket size for heater element
can anyone tell me what the socket size is for a Suburban water heater element, tried to put a set of calipers but closest I could get was a guess ( too tight quarters) was 1.5 inch
  • Home depot and Lowes sell a cheap element socket wrench for around $6. They are usually right by the elements. The 1400W or 1440W elements they sell will work in your WH. I found Camco elements at Ace hardware.
  • Clicky
    The real trick is to have a 1.5 inch socket that is flush at the end, and not rounded.
  • My Suburban water heater anode rod takes a 1 1/16th socket. Be sure to get a deep socket or use an extension for easier access.
  • lenr wrote:
    Mine is 1 1/16" U.S.
    Anode rod, or heating element?
  • The stamped steel socket type wrench I have downstairs measure 1 9/16". It doesn't have a size marked, but that is what I got when I measured it with a set of dial calipers.
    I got it at the RV shop, was $6 I think.
    Head to the nearest hardware store and measure one of the heating elements they have on the rack.
