garyemunson
Oct 19, 2019Explorer II
I would suspect the two windows. Have you taken a screwdriver and tightened all the screws around the inside of the window frame? The most important ones are across the top and usually forgotten as they are hidden behind the top valance/blinds. The tape sealer between the window and wall keeps getting compressed as the RV flexes going down the road. That's a maintainence item that should be done annually. The butyl tape sealer is usually good for 10 years so I really don't think you need to pull the windows out.
