obiwancanoli's avatar
obiwancanoli
Solar - Permanent mount or portable?
As I work through the process of upgrading batteries, either a 4-jar bank of Lithium 100Ah 12V, one 300Ah + a 100 Ah, or two 200 Ah, I'm also researching the addition of more solar panels to the roof of my Class A. My boondocking plans in the years to come require a more serious look at power needs and requirements.
Currently, I have 3 - 160W solar panels - 26.1 amps total output, fixed to the roof, a 30A PWM Controller, and have room for up to 4-5 more, depending on configuration. Of course, will need a new Controller if I do so. For the solar wattage I'm considering, some sites have suggested an 80A MPPT Controller. I initially thought a 60A would do the trick, but I was basing that on the total amp output of all panels. I also have a 120W, 5.6A portable.
I'm thinking I might be better off using portable panels. As a practical matter, at 100-120W per portable panel, I'd need at least 3, probably 4 to reach my goal.
It might make sense to have some of my charging capacity in panels I can move around when shade impedes. I understand some can be hooked together, but then, there's the inconvenience of having to store, set up, and take down 4 folding portable panels. Perhaps just two?
I understand each person will have different needs and requirements, but is this a balance some strike, where solar is concerned? Or are there 'druthers out there who swear by one way or the other?
As an aside, I have a Trav'ler II mounted to my roof, but have considered picking up a portable sat dish - again, when I find myself in the trees...
Having RV issues? Connect with others who have been in your shoes.24,300 PostsLatest Activity: Aug 12, 2025
