ewarnerusa's avatar
Sep 13, 2016
SOLAR - Switch from PWM to MPPT, series vs parallel matter?
I put together a solar setup on our TT when we bought it new. I went with 2 x 140 watt 12V nominal panels in parallel and a PWM controller.
Panel specs:
Max Power: 140Wp
Open Circuit Voltage (Voc): 21.0V
Short Circuit Current (Isc): 8.40A
Maximum Power Voltage (Vmp): 17.0V
Maximum Power Current (Imp): 8.00A
There are quite a few MPPT controllers out there now that aren't terribly expensive (under $200). I have contemplated swapping the PWM controller to an MPPT as a way to squeeze some more potential bulk charging amps out of the panels without having to do anything else besides swapping controllers. I know there are some benefits for running panels in series to double the voltage and cut down on wire gauge needs. But my panels are already in parallel with fat wiring from junction box to controller (4 gauge). It seems to me that the math for potential max charging amps works out the same whether my panels are in parallel or series. Is that correct?
Having RV issues? Connect with others who have been in your shoes.24,251 PostsLatest Activity: May 18, 2025
