MrWizard
Nov 25, 2014Moderator
in our 95 Safari.. I switched the OEM system to the chassis batteries
Then bought panels for the house side
My Siemens panels are 15.7 volt
Anything you buy now will be at least 17+ volts and probably even higher
Tying them together won't work very well
And safari does make it...long wiring from roof vent to batteries
I put the charge controller in the compartment under the fridge
Then ran the charge wires backup and through the bottom of the closets to come out near the batteries
The only way to get the controller closer..would be in the closet or in the bedroom
Having RV issues? Connect with others who have been in your shoes.24,397 PostsLatest Activity: Jun 25, 2026
