BFL13
Jun 23, 2015Explorer II
Joel_T wrote:
So, if I have a 30amp controller running 2 160watt panels what size circuit breaker fuses will work between controller and battery....30a....50a? (Besides a 40a that is, that are backordered a month and a half.)
Expect 320/130 x 8.2 = 20 amps with panels aimed at high sun at STC so 1.25 that is 25 amps to allow for on wire gauge choice.
Then fuse to what wire gauge you actually picked (overdo the wire to reduce voltage drop.) IMO a few feet of #8 wire and a 30a fuse would work.
Having RV issues? Connect with others who have been in your shoes.24,413 PostsLatest Activity: Sep 14, 2026
