2oldman
Jul 27, 2017Explorer II
BFL13 wrote:1 amp might matter to some, not me.
but then who cares if you are getting 1 amp instead of none? In four hours that would get you a whole 4 AH. Gosh! :)
I just can't see the point except for the wiring thing. If your wires are fat enough, why not just leave the panels in parallel in case there is some shading, since you (at least I ) get the same amps either way, even in "low light" ?
My coach was "solar ready" with 10awg wire from the roof to basement. For 6 panels that means higher voltage. And series wiring is so much simpler. Plus I just like doing things differently than most. You know, a bit "out of the box."
Having RV issues? Connect with others who have been in your shoes.24,362 PostsLatest Activity: Mar 02, 2026
