mike-s
Jul 27, 2017Explorer II
time2roll wrote:The reason for using PWM is cost. It's hard to picture any scenario where one would be more efficient than an MPPT. If you don't have a controller, buying PWM makes sense for small systems, but if you already have an MPPT, no reason not to use it.
The reason to go parallel is to use a PWM controller.
Did you do that when you switched to parallel?
Having RV issues? Connect with others who have been in your shoes.24,362 PostsLatest Activity: Mar 02, 2026
