Acampingwewillg's avatar
Acampingwewillg
Explorer II
Aug 22, 2013
Solar again?
Hi all
I know, Im sure this has been answered before somewhere here but what the heck. While I was just sitting being lazy today, I said why don't I go on top of the MH and measure some to see what kind of room I have up their. Well, between all the antenna's, air conditioners, vents and such, I came up with some figures.
After looking at dimensions of some of the larger 24 volt panels, it started to look like I might be better off with the smaller 12 volt 100-140 watt types. Anyways, it appears I may have room for 4-6 panels probably configured in 2 or 3 two panel groups. Im getting to the question.....would it be wise to series wire each set of two panels and then parallel, giving me 2 or 3 24 volt arrays? Im just in the "thinking" process now but since I took the first step to measure, may as well ask away....:B
We don't do a lot of dry camping/boondocking but I could do a lot more, I currently have (6) 6 volt batteries.
  • gatorcq wrote:
    http://www.batterystuff.com/kb/tools/solar-calculator-tutorial.html
    http://forums.trailerlife.com/Index.cfm/fuseaction/thread/tid/25705772/srt/pa/pging/1/page/1.cfm
    http://www.jackdanmayer.com/rv_electrical_and_solar.htm#The Golden Rules
    I choose to use the quick reply, instead of inserting Links.
    Everything you really wanted to know is here.
  • You should consider the shipping costs asssociated with the larger panels as well as the logistics of getting them up top and mounted. Check out the dimensions/weights look at UPS web site them check out the alternatives many are very pricey
    Yes sure a series parallel arrangement of the panels can be used as well as a simple parallel arrangement or a total series. Too many variables to offer much more.
  • http://www.batterystuff.com/kb/tools/solar-calculator-tutorial.html
  • Hi,
    If using 17 volt panels it may be cheaper and better to wire them in parallel and use a pwm controller with a temperature probe to optimize charging voltage.
    If you wire them in series/parallel a more expensive MPPT controller must be used.
    When panels were more expensive mppt made good sense. Now they are dirt cheap the greater ability to wring watts out of the panels is not quite so important.
Having RV issues? Connect with others who have been in your shoes.24,189 PostsLatest Activity: Jan 21, 2025
