CA_Traveler
Aug 17, 2019Explorer III
theoldwizard1 wrote:24V panels provide lower cost/watt and smaller footprint/watt. Wiring is smaller/cheaper.time2roll wrote:
MPPT is ok but max input is 25v so limits you to 12v panels.
I don't see this as much of a problem. Higher solar voltage are typically only used when the wire runs from the panels to the controller are long.
With serial connected panels shaded power is higher than parallel panels due to bypass diodes. And a combiner is eliminated along with the larger combiner to controller wiring.
MPPT controller is required for 12V batteries, higher controller input voltage and the panels are larger - typically 60 or more cells vs 36 for 12V panels.
