BFL13 wrote:
So it is ok to do several 50-90s in a row with AGMs, then go home and recharge to full (.5a/100AH) at the specified 14.x level for that model AGM, and then go to float voltage until the next trip?
No need for a 20% recharge in that case?
Dangerous to interpret when noise to signal ratio is high, isn't it...
I don't think this is ok. Better not to run 50-90 for prolonged time. Especially if solar is all you have.
Scenario: 300AH bank on 490W solar is 80-85% before sunrise, goes into Float around noon when current drops to preset value (AGM at 95-96% at this point?), and then stays in Float for 6-8 hours. Sort of a standby service. Generator-shmackerator...
