BFL13 wrote:
What about Trojan saying better not to Float the AGMs between trips if going out once a month or more often (leave them disconnected presumably)?
"Avoid using continuous float charging on VRLA batteries that are charged more than once/month."
Don't know whether there is more context but it is is not clear what they mean by "continuous float charging". Is it float each time after discharging i.e. never bring them to V Abs (obviously a bad idea), or floating between the trips (on which trips it was discharged and then charged to unknown SOC that might as well be past V Abs)?
Again, 20% "rule" (that has been the source of pain with the OP Lifeline) doesn't directly come into play here.
