phemens's avatar
phemens
Solar Array - 12v & 24v concurrently?
I have 3 12v panels (2x 80w, 1 x 135w) feeding into a Rogue 3024 MPPT controller, which then feeds 4 x T125 Trojans. I want to add another panel, was wondering if there is any way to add a 24v panel as a 2nd array to the 3024, or do I have to add another 12v to the existing array?
  • 3_tons's avatar
    3_tons
    Explorer III
    You can do it, but the 24v panel will simply default to the lower voltage of the 12v panels.
  • second separate controller
    the voltage difference between the 24sys panel and the 12v sys panel is TOO much
  • You can always have a second controller on the same battery bank as the other. If you have a good deal on a big 24v panel and need an MPPT controller for it, the Eco-Worthy at $102 US is perfect.
    Last year I was doing that with my 24v 230w and the 12v 130w in separate arrays on the same bank. They add their amps when you make both to the same voltage settings.
  • The Rogue 3024 is 30 amp with max VoC of 60v. I was hoping I could just plug the new panel in as a 2nd array separate to the existing one, but it looks like it's limited to one PV. Not sure I want to go through the trouble of rewiring everything to try and achieve 24v as BLF13 suggests, I guess I'll stick with a 12v panel. Thanks!
  • BFL13 wrote:
    Also you might run out of wire! :)
    And you'll need help figuring out how to connect all that wire! Be sure you have a VOM at your side.
    the two 80s in parallel for 12v 160 and that in series with the 12v 135 makes a 24v, then parallel that 24 with the new single 24. However I do not know the controller's Voc or amps limits
