KenS999 wrote:
I am charging strictly by solar. Charge controller is a Renogy Voyager. Absorption phase of charging cycle always runs at 14.7V. Equalization is automatically run by charge controller when necessary. Until recently I was able to achieve float within 3-4 hours. Now it can take 6 to 7 hours to achieve float. Thanks,Ken
Impossible with a 100W panel alone, you have killed your batteries capacity by drastically UNDER CHARGING!
There is no way a 100W panel can sustain enough amperage to effectively charge a battery to full in 3-4 hrs at 2.5A per battery.
KenS999 wrote:
The two lead acid Duralast batteries that I charge with the Renogy 100W solar suitcase are rated at 65 amp hours each.
According to the charge controller specs, Equalization will automatically occur every 28 days in the charge cycle @ 15.5V unless otherwise required.
Just ordered a temperature correcting hydrometer online. Thanks, Ken
100W "suitcase is not "rated 65Ahr", more like 6.5A hr and that would be in full sun at noon during the summer solstice with the panel pointed directly at the sun with no clouds in the sky. That max only lasts at best 4hr-5hrs a day.
Specs on the panel are..
"If you're looking for a convenient and portable power solution, the Renogy 100W Monocrystalline Foldable Solar Suitcase is an ideal choice.
The Renogy 100 Watt 12 Volt Monocrystalline Portable Solar Suitcase is an entire solar power system incorporated into one small package. Weighing in at about 27.60 lbs, this lightweight suitcase includes two 50 Watt Monocrystalline Solar Panels, one 30 Amp Adventurer Charge Controller with an LCD Screen for power regulation, one 10ft tray cable with alligator clips for easy connection to the battery, one temperature sensor, one battery voltage sensor, and a protective casing for safe portability. The Renogy 100 Watt Solar Suitcase will make charging on the go as easy as 1-2-3!
Please Note: The Charge Controller is Not Waterproof.
Renogy 100W Foldable Solar Suitcase
Maximum Power: 100W
Maximum Operating Voltage (Vmp): 18.0V
Maximum Operating Current (Imp): 5.71A
Open-Circuit Voltage (Voc): 21.6V
Short-Circuit Current (Isc): 6.17A
Operating Temperature: -40°F to +185°F
Folded Dimension: 19.9 x 27.2 x 2.4 inches
Weight:27.65 lbs
Renogy 30A ADV Charge Controller
Nominal Voltage: 12 VDC
Rated Charge Current: 30A
Max. PV Input Voltage: 25 VDC
Float Voltage: 13.8 V
Under Voltage 12 V
Operating Temperature: -13°F to +131°F
Terminals: Up to #4 AWG"Note the bolded text, yeah that is 5.7A..
If it was 65Ahr, that would be on the order of 57.1A!
To get the 65Ahr you would need 10 of those panels.
Just because your controller may shift voltages, doesn't mean the batteries are getting more than a trickle charge.
You NEED more panels if you want to stop killing your batteries or connect to shore power.
