jonlin's avatar
jonlin
battery charging
We are staying in a campground that has no hookups, therefore we are having to run on our batteries. We have an 09 40' Phaeton with a commercial frig with 6 house batteries. No problem with charging the batteries with the house generator; however, when I try and charge the batteries with a 2000 Honda the batteries will not charge. I have tried running the Honda through a ground fault and it gives me a caution when flashing indication. The ground fault was working properly last week when we had the coach plugged into a 110 outlet. I also removed the ground fault and hooked the coach straight to the Honda and the system status in the coach would still show inverting. Questions: 1) Is a Honda 2000 big enough to charge the batteries on a coach this size? 2) blown fuse somewhere? I have checked the reset on the Honda. Thank You! John
