pianotuna
Apr 27, 2013Nomad III
Hi CA Traveler,
There is a limit to where everything can be "put". I already have one "corner" which was (fortunately) wasted space. Now I can use the space above it for a 2nd controller (maybe), or I can go for one much larger controller and "do everything". I know there are controllers with dual outputs. Is there one with dual inputs?
CA Traveler wrote:I'll only be adding one controller--due to space considerationsThis seems inconsistent with 6 panels. Care to explain?
Morningstar is limited to 3 of your panels. Outback and Midnight have 80A+ controllers so 4 panels could be used.
You could use the Morningstar with a 24V battery bank. :B
Having RV issues? Connect with others who have been in your shoes.24,383 PostsLatest Activity: Apr 25, 2026
