pianotuna
Apr 27, 2013Nomad III
Hi Salvo,
Thanks!
I expect I'll do as I did with the unisolar's and use angle aluminum along the long side of the panels.
Thanks!
Salvo wrote:
I think both the poly and mono panels have similar low irradiance efficiencies. The mono has a good spec, while the poly has missing I-V curves. I would decide at the shop. See which panel is better made. How much does the frame flex? Take a multimeter along. Measure Isc (if they allow).
Sal
Having RV issues? Connect with others who have been in your shoes.24,383 PostsLatest Activity: Apr 25, 2026
