Salvo
Apr 29, 2013Explorer
The test you linked was never completed. Also, covering up one or two cells is not how shading works. In the real world, shaded cells still get light. If the shaded cells get enough light then the bypass diodes won't conduct. Now the series system is in deep dudu.
I believe you did some testing by covering up cells with a blanket. That test will make series look good.
Sal
Sal
2oldman wrote:Salvo wrote:No, it isn't.
The series vs parallel debate is not as clear cut as some think.
Series solar testing
In my case of 6 panels in series I see no drastic power loss with one whole shaded panel. But, again, that's MY case. YMMV.
Having RV issues? Connect with others who have been in your shoes.24,381 PostsLatest Activity: Apr 21, 2026
