Son_of_Norway's avatar
Sep 08, 2020
Solar Cable Tangles
Hello; I have two solar suitcase panels that I set outside the RV. I run an 8 gauge solar cable out to them. I have a couple of sets of cables so I can add length if I need to, for a total of about 20 feet. Of course, each cable has 2 cables, a + and a -. My problem is that is a lot of cable and gets tangled easily.
How can I combine the + and the -? I thought about plastic wire conduit but even 1/2" isn't big enough for two 8 gauge cables. I also considered just using pieces of electrical tape every couple of feet but the tape gets crappy after a while. What can I do to avoid a tangle?
Thanks for your ideas.
  • Either a split loom or a spiral wire loom would probably work well. These are often available at auto parts stores.
  • Those must be big panels or far from the controller if you are using 8 gauge.”Tangles” are another reason for roof mounted panels.
Having RV issues? Connect with others who have been in your shoes.24,370 PostsLatest Activity: Mar 17, 2026
