JimK-NY's avatar
JimK-NY
Explorer II
May 12, 2017
Solar Charge Controller Advice Needed
I have a truck camper with a 7 year old solar system: 2x135 watt Kyocera panels in parallel, 2x150AH Lifeline AGM batteries and a cheapie replacement Nature Power controller.
I have a compressor refrigerator and my wife uses a CPAP. I will be traveling this fall and winter and need to get the most out of my solar system. The single stage pwm controller is obviously a weak link so I just ordered a Blue Sky 3000i MPPT controller with a temperature probe. I probably should have asked for advice first, but I can still cancel the order if there are contrary recommendations.
Thanks
BTW, I should have also mentioned I do not have room for any additional panels or batteries.
  • Blue Sky is a good cost effective improvement over the Nature Power.
    Install and enjoy your trip.
    I think Morningstar is a bit better but will cost more and the improvement may not be significant at this level.
  • Blue Sky makes an excellent charge controller. The IPN remote will allow you to program and monitor a lot of different things with the charge controller; it isn't just for multiple units.
  • How much extra do ya get in float?
    Ya gonna get to float regularly?
    abs should last till .5% of batt capacity.
  • red31 wrote:
    set the nature power to 14.4v when on the road and be done with it.
    I actually considered that, but of course the issue is trying to constantly adjust so that the batteries do not float at that voltage. The other issue is the overall efficiency of MPPT which should give me 10 to as much as a 30 percent boost.
  • set the nature power to 14.4v when on the road and be done with it.
  • The way the system was installed I cannot access or change the wiring without trying to remove the solar panels. I believe the prewiring from Northstar was 10 gauge. I have no idea how long the wiring run is. It looks like it would need to be 10 - 15 feet.
    What does the IPN do? I thought that was used to manage multiple controllers.
  • Look at the Tracer BN series. It is considerably cheaper than the Blue Sky and is a Morningstar clone. It does allow for a battery temperature sensor and has adjustable voltage sense points IIRC.
    What is the voltage on the panels?
    The Blue Sky dip switches don't give you much control of the unit. To extract every watt you may need to add the IPN remote to the Blue Sky.
  • What are the sizes and lengths of wire from the panels to the controller and from the controller to the batteries?
  • to get the most efficient use of your new controller
    Reconnect the panels in series, you will gain a little more on morning and afternoon power output
Having RV issues? Connect with others who have been in your shoes.24,311 PostsLatest Activity: Sep 05, 2025
