Diesel_Camper's avatar
Feb 01, 2016
Solar charge controller coupled to power converter question
I've noticed through several days of testing that my converter drops out of bulk charge mode loooong before the batteries are where they should be, and in float mode it would take a couple weeks (if ever) to finish the charge acording to hydrometer readings.
I was considering adding a charge controller between the converter and batteries. I'm hoping this would maintain a charge voltage high enough to deliver a decent charge, and the higher current would lower the voltage between the converter and controller enough to kick the controller into boost and provide the amps for the charge.
The logic in the converter is that it attempts to reach 14.4v in boost mode or it times out in 4 hours and drops to 13.6v. If the voltage drops below 13.2, it goes back in to boost.
I was thinking this logic might play nicely with the charge controller, and I could set the volts on it to 14.8 which would give me a nice charge.
Will this work?
Also, are there any programmable converters out there?
Having RV issues? Connect with others who have been in your shoes.24,373 PostsLatest Activity: Apr 02, 2026
