red31
Aug 21, 2019Explorer
OP, the concept is both battery and panel voltage should rise to 14.4v. Then battery voltage is held there for 10 mins (per info in above link), then the battery is allowed to drop to 13.6v and held constant. Measured panel voltage after the battery gets to 14.4v will rise as the panel is now operating at battery voltage and panel Voc On and off rapidly.
Adding loads at any time to the above charge cycle may extend any mode and/or not allow the controller to change modes for instance if battery v never gets to 14.4v then the next 2 modes never happen. A draw down from 13.6 float to 13.2v restarts the charge cycle.
Having RV issues? Connect with others who have been in your shoes.24,381 PostsLatest Activity: Apr 18, 2026
