DarkSkySeeker's avatar
Apr 19, 2020
Solar Charging and Amp Hours
Is the amperage from a solar panel constant as the battery it is charging charges up?
I.e., as your battery reaches full charge, the current drops to zero either via the charge controller or the equalization of the panel and battery, right?
So this simple math is false? 120 watt panel, 12 volt system, 10 amps, 10 hours to charge a 100 Amp Hour battery?
  • yes, cuz it is not connected to anything!
    excess power is not made, the panel is disconnected from the controller.
    The on/off connection to the panel is done at high freq, the OFF time gets longer and longer to limit power to the controller/battery.
    add a big load and then the battery is getting very little but the controller allows the extra to run the load.
  • DarkSkySeeker wrote:
    And the power output of the panel drops down? Eventually meaning a 100 watt panel no longer puts out any power?
    Power (watts) = amps x volts..... Zero amps, zero power.
  • Thank you for this help. In my mind, I thought only the battery side of the controller was modulated. Now I understand the charge controller allows current flow from the panel in the same way.
    Amps are DRAWN by the consuming device. That is why your 1 Amp incandescent bulb does not explode when connected the same battery that can send 200A to the starter motor. You explode the bulb by applying too much Voltage.
    HTH;
    John
