DarkSkySeeker's avatar
Apr 19, 2020
Solar Charging and Amp Hours
Is the amperage from a solar panel constant as the battery it is charging charges up?
I.e., as your battery reaches full charge, the current drops to zero either via the charge controller or the equalization of the panel and battery, right?
So this simple math is false? 120 watt panel, 12 volt system, 10 amps, 10 hours to charge a 100 Amp Hour battery?
Having RV issues? Connect with others who have been in your shoes.24,303 PostsLatest Activity: Aug 21, 2025
