- brulazExplorer
Almot wrote:
$6 4x4 PVC weather junction proof box from Home Depot. Comes with a rubber gasket. The sun will do a number on it. Should last some years, depending on the area.
Used one of those. Painted it white to help against the UV. - AlmotExplorer III$6 4x4 PVC weather junction proof box from Home Depot. Comes with a rubber gasket. The sun will do a number on it. Should last some years, depending on the area.
AM Solar have a J-box that mounts on the side of fridge vent, $60. It's "supposed" to go under the vent hood, but on finished installs I see the soft hood plastic bulging a little there. - RJsfishinExplorerThat's what I used. I could have went a little bigger, it was tight w/ 3 panels and the buss bars.
- pigman1Explorer
Calkidd wrote:
Pretty much what I did. I did use pre-made electrical ground bars I got from Lowes. I glued a PVC divider between the hot side and the ground side, used waterproof cable connectors where the panel wires come in and my heavy weight down wires to my controller leave from the bottom of the box with a conduit connector and a conduit going all the way down to the RV basement. I also bring each pair of panel wires (six 140W panels) into the box individually and connect them to the bus bars with a mini fuse in the + side. This allows me to connect or drop off individual panels without having loose hot wire ends touching things they shouldn't. Also makes troubleshooting individual panel output easy.
Thus is what I am going to do.
Combiner box - CalkiddExplorer
Having RV issues? Connect with others who have been in your shoes.24,348 PostsLatest Activity: Jan 13, 2026
