Colo_Native's avatar
Colo_Native
Solar combiner box
Anyone made there own combiner box if so how and what did you use. Am solar has one for $80 but I am sure it can be built for a lot less.
  • Almot wrote:
    $6 4x4 PVC weather junction proof box from Home Depot. Comes with a rubber gasket. The sun will do a number on it. Should last some years, depending on the area.
    Used one of those. Painted it white to help against the UV.
  • Almot's avatar
    Almot
    Explorer III
    AM Solar have a J-box that mounts on the side of fridge vent, $60. It's "supposed" to go under the vent hood, but on finished installs I see the soft hood plastic bulging a little there.
  • That's what I used. I could have went a little bigger, it was tight w/ 3 panels and the buss bars.
  • Calkidd wrote:
    Thus is what I am going to do.
    Combiner box
    Pretty much what I did. I did use pre-made electrical ground bars I got from Lowes. I glued a PVC divider between the hot side and the ground side, used waterproof cable connectors where the panel wires come in and my heavy weight down wires to my controller leave from the bottom of the box with a conduit connector and a conduit going all the way down to the RV basement. I also bring each pair of panel wires (six 140W panels) into the box individually and connect them to the bus bars with a mini fuse in the + side. This allows me to connect or drop off individual panels without having loose hot wire ends touching things they shouldn't. Also makes troubleshooting individual panel output easy.
Having RV issues? Connect with others who have been in your shoes.24,361 PostsLatest Activity: Feb 22, 2026
