MrWizard
Aug 30, 2018Moderator
BFL13 wrote:
Thanks. So that's one. Note that when trying for 0.5 amps on a 100AH AGM, 0.2 matters.
i think you are missing something here, in the logic
everything using power, or charging
is on the output side of the shunt
what gets measured by the shunt , is what the battery is accepting
all loads, including the solar controller (which only has use drain when there is NO solar or other charging being applied)
0.5amps thru the victron ? shunt to the battery is 0.5amps
no need to calculate other loads and try to figure out where 0,2 for the controller is going
it is used before the shunt
