CA_Traveler
Aug 31, 2018Explorer III
BFL13 wrote:Yes it does, which is why I don't check the solar output but rather check upon the Trimetric. Even if there were no house loads the calibrated Trimetric shunt is more accurate than my CC and I suspect most readings.
Thanks. So that's one. Note that when trying for 0.5 amps on a 100AH AGM, 0.2 matters.
And then there is my Magnum charger. 50A display means 50A more or less. 1A means it's clueless.
