BFL13
Aug 31, 2018Explorer II
pianotuna wrote:
If I use the main battery disconnect, because my inverter/charger is direct wired to the battery bank, I would have no loads while charging. The same is true of the solar.
Not quite the same. If you had the disconnect on the battery side and disconnected the batteries, you would get nothing to the loads since the charger part would not work.
If you did that with the solar controller or converter you would get power to the loads (except for some controllers that want the battery connected too or they will fry)
