mike-s
Aug 31, 2018Explorer II
BFL13 wrote:Well, that's just plain wrong. You can't have power both go into and out of a battery at the same time. Like many solar controllers, no doubt many inverter/chargers need to initially draw power from the battery to power up their control circuits and become operational. But, once they start charging (using either solar or AC power input), they're powering themselves, and what's left goes to the battery.
I probably got what Doug said confused too. Here is what he said:
"..... Inverter/Chargers supply power TO THE BATTERIES, then the batteries supply power to the RV 12 volt systems. ........"
And, as long as everything is wired through the shunt as it should be, the Trimetric will only see what's actually going into/out of the battery. It doesn't know or care about anything connected to the "load" side of the shunt.
Again, what size is your inverter?
