TravisG
Apr 26, 2017Explorer
Solar controller questions/help
First I would like to apologize if this is a dumb question. We installed two 165 watt solar panels and a charge controller wired to two 12 volt batteries in parallel this winter. Charging light came on and I haven't really given it much thought until today.....
Today I went into the trailer just to look around and check on stuff and to check the charge controller. The charger wasn't indicating that it was charging and read that it was at 13.9 volts. The little tattle tale lights on the wall were only showing three out of four lit up.(I know they aren't very reliable btw) I thought I would check at the batteries to see what voltage they were putting out. Pulled off the covers and they are reading 11.89 volts.
My question is this, shouldn't in theory the charge controller be reading the same voltage as my meter did when I checked it with my meter?
A couple of readings from the charge controller in case it helps and I am doing something wrong...
Load 00.0 Amps
Charge 00.0 Amps
Battery SOC 100%
Charge off 31.7 Volts
Load off 10.5 Volts
Load on 12.5 Volts
Load 00.0 Amps
Charge 00.0 Amps
Battery SOC 100%
Load off 10.5 Volts
Load on 12.5 Volts
