BFL13
Sep 08, 2014Explorer II
smkettner wrote:
6' is fine. Use max wire the terminals accept.
You are allowed to use the max terminal size wire as short pigtails to join with fatter wire for the long run. You can also shave some strands from the fat wire till it fits in the terminal (set-screw type) There are even step down wire lug terminals you can buy that can then fit in the controller terminals.
