TUCQUALA
Jul 20, 2015Explorer
Solar Controller Wiring ?
I see most controllers have + & - inputs for the panels and the same for the battery ('ies) that are separated. I've also seen some lower wattage that have the negative in common with the battery.
Question is, can a lower wattage panel (40-60w) be wired into a average 10A mppt controller with the negative connected to the battery or commoned at the controller??? Will all be well, or will all H**L break loose!!!???
Just askin'!!!
Gerry
Just askin'!!!
Gerry
