westend
May 10, 2015Explorer
Seems like a good list. I'd also choose the Bogart gear, I've seen how it was built and appears to be built with quality in mind.
Some things that be helpful- switch/breaker between modules and charge controller. First off and last on when working with downstream 12V. I went with one of these mid-range manual CB.
If the controller's output terminals are too small for the cable you want to use, spade lug connectors are available that fit the terminal space. I bought the gold plated ones for $5.
Heat shrink, get a bunch. I try to buy it local.
Good luck with the installation. Solar is better than sliced bread!:B
Having RV issues? Connect with others who have been in your shoes.24,404 PostsLatest Activity: Aug 06, 2026
