grizzzman
May 11, 2015Explorer
Chilepalace wrote:
I would like begin my first post with a big thank you to all who have shared their knowledge and experience on this forum. Without that, I probably wouldn't be entering the solar jungle!
I hope you will take a look at my plan,(will try to keep it short), and alert me to any big mistakes I am about to make.
The rig: 27' 5er, 2 Trojan T-105 batteries. Lots of dry camping, however our power needs are minimal. No plans for a large inverter or power hungry appliances. LED's already installed. Usually camp in warm, sunny places, often at 11,000ft. elevation.
The equipment:
Solar Cynergy 300W kit from Solarblvd. $415/free shipping.
Includes:
2 150W mono panels
Solar Cynergy 20amp controller(probably not use).
40' of 10Ga. cable w/mc4 connectors, 2 mc4 Y connectors.
8 'Z' brackets(won't use).
Trimetric SC2030 controller kit from solarseller.com. $340 w/shipping.
Includes:
30amp PWM Controller and 2030RV monitor.
500amp shunt.
Monitor wiring harness and temp. sensor w/connectors.
Battery cables,fuses, disconnects, panel mounting hardware: <$200? So maybe do this for just under $1000. Worth it?
My main questions for all of you:
Is the above controller & monitor a good choice for my system?
Would an MPPT controller justify the extra cost? I have been trying to research the Tracer 4215Bn with Mt50 remote monitor. Haven't had any luck finding adequate info.(or suppliers) on these units.
Wire size: Approx. 12' run from panels to controller, is 10 ga. supplied in the kit adequate? 4' controller to batteries, 4ga. welding cable OK?
Thank you for any comments/suggestions you care to share.
I have the trimetric TM2030 and SC2030 system and i would highly recommend it. One of the big mistakes people make is to small wire size. I would suggest that you use AGW 6 from the panels to the controller. AGW 4 will be fine. The Trimetric system has voltage compisation as long as the losses from the panels are not to high. For what its worth i built a combiner box for about 14 dollars using stuff from homedepot. Good luck with your build!
Having RV issues? Connect with others who have been in your shoes.24,404 PostsLatest Activity: Aug 06, 2026
