Fisherguy
May 21, 2015Explorer
scrubjaysnest wrote:
225AH*14.5 volts charging * 1/0.77 panel + CC loss * 0.1(10% roc) = 424 watts of solar needed. System is marginal unless very conservative. Go with the Bogart set-up and maybe a fourth panel. You can get by with the 300 watts as you will still be above the 5% minimum roc that Trojan recommends. The batteries will be happier with 10%.
Considering going solar myself, lots to learn.
Can you explain:
"225AH*14.5 volts charging * 1/0.77 panel + CC loss * 0.1(10% roc) = 424 watts of solar needed."
You say his system would be marginal then say he'll be fine?
Having RV issues? Connect with others who have been in your shoes.24,404 PostsLatest Activity: Aug 06, 2026
