BFL13
May 22, 2015Explorer II
pianotuna wrote:
Hi BFL13,
You need more wattage with a tiny bank because the depth of discharge is going to be greater.....
Descriptive vs prescriptive again. The charging rate IS higher on the smaller bank accepting the same amps but you don't need more array to be at the same amps.
The two batt bank will be at 50% and the four batt bank will be at 75% going in.
Each needs the same AH to get to 100%. Assuming the solar can do that many AH that day, the time is the same, the AH is the same, so the amps must be the same.
Same amps, same size solar array.
Having RV issues? Connect with others who have been in your shoes.24,403 PostsLatest Activity: Aug 02, 2026
