reed_cundiff
May 24, 2015Explorer
Don - there are a lot of advantages to LFP and two major ones: cost and possibility of damage at high rate of charge below 0 C. As noted above, weight is critical to us. Industrial standard for lead acid is is 72# (33kg) per 100 amp-hr (12 V nominal)(http://www.powerstream.com/Size_SLA.htm) so b may be hauling 1100 pounds (511 kg). We have 7 kW-hr of usable which would be about 14 kW-hr (1170 Amp-hr at 12 V) of lead-acid which is a bit less than b's usable. I feel pedantic about putting this in to you two but a few folks that read these fora don't know the difference between usable and stated Amp-hr (kW-hr).
b - hope paths cross but not with to many young Grizzlies like at Chewing Black Bones.
Reed and Elaine
Reed and Elaine
Having RV issues? Connect with others who have been in your shoes.24,413 PostsLatest Activity: Sep 14, 2026
