DesertMax
May 29, 2016Explorer
Also, I'm thinking of building a lower step (battery enclosure) on the floor at the very front of the camper to house 2 more batts for a 36V system..
I used my cooler as a "batt place holder" just for the shot..
There is 30" of usable width space and I don't need the factory step so that won't be a problem.. Question is, while AGM's are "sealed," is it really actually safe to have 2 of them in the living area? I'm thinking to put them inside battery boxes and then again inside of a wooden constructed enclosure and carpet the top of it to match the interior carpeting..
I have in the past, used the camper corner spaces in the truck bed for batts but the Squire 3000 is compact and the crawlspace doors are too small to access the batts unless I built them in and then loaded the camper "over" them which sounds tricky upon tricky as loading a slide in is never fun in the first place...
Having RV issues? Connect with others who have been in your shoes.24,397 PostsLatest Activity: Jan 16, 2025
