Almot
May 29, 2016Explorer III
DesertMax wrote:
isn't the "sealed" factor for just that purpose... safe, no spill, no vapor or venting.. can be mounted on their sides etc???
yes on all 3.
Safe as any battery is safe. You can kill yourself with a toothbrush if you try hard.
No spill.
No hydrogen vapor unless during extreme overcharging, and then there is a relief valve for that. If you remember some cars have regular spill-able battery mounted inside, in the back or under the seat.
Can be mounted on the sides, though this tends to be more complicated, with a rack and some plastic to keep contacts covered.
AGM make a lot of sense for a small van or TC.
Having RV issues? Connect with others who have been in your shoes.24,397 PostsLatest Activity: Jan 16, 2025
