JiminDenver
Jul 12, 2015Explorer II
There are various ways of setting up solar.
Add up the Ah ratings of the batteries and have 1 watt per Ah.
The balanced approach means knowing how much power you need, having the battery to provide it when the sun doesn't shine for a few days. Enough solar to bring those batteries back up relatively fast when the sun does come back, and some form of alternate charging when the sun hides for too long.
The last one is cover the roof in panels, fill the bay with batteries and you are maxed out. Should that not be enough power, learn to conserve either painlessly with LED lighting and lower power TV's and such, or the hard way of simply not using as much power.
So unless you are going for the last one, you need to know what you want.
Having RV issues? Connect with others who have been in your shoes.24,389 PostsLatest Activity: May 28, 2026
