vic46
Jul 15, 2015Explorer
Canadian Rainbirds wrote:
vic46, Please don't get too annoyed with Mexicowanderer. Or, go ahead and get annoyed (Yes, D. You can be annoying at times, though usually funny) but if you keep him blocked you will be blocking probably the most knowledgeable person here on lead acid batteries, their care, use and abuse. I think MW gets a little tired of repeating himself.
As for your original post and recaping some of the comments;
100 watts is NOTHING for the size of your house battery bank. Your batteries will handle a relatively large solar array.. BUT do you need it?
As has been mentioned, you need to do an energy audit and also decide how much time you are going to spend off grid.
Here are some numbers from a tongue in cheek post I made on another thread. It kind of puts solar energy in perspective.
First, think in Watts, not Amps. (Watts are Volts times Amps, so 10 Amps at 12 volts is 120 watts, as is 1 Amp at 120 Volts)
I am a big fan of solar, we have 420 watts (yes I'd like more) which is more than many if not most.
746 watts of solar panel is a larger than average solar installation for an RV;
(I chose 746 watts because that is ONE horsepower, for a perspective view)
The total solar energy reaching the earth's surface is on average slightly under 1400 watts(less than two horsepower) per square meter.
One electric appliance (kettle, toaster etc) runs 1200 Watts.
You need the batteries to store that energy so you can use it when you need it, and so that can use more energy than the sun is actually providing at the time.
The bigger the solar array the faster the batteries will recharge and store that energy for later.
You also need enough panels to get the the battery voltage up high enough for long enough to get them properly charged (up to 15 volts at times).
When you do your installation use the largest wires possible (within reason)so that you won't have to change them when you decide that you need more panels. (Almost everyone that goes solar adds to it eventually.)
Start learning and researching and don't hesitate to come back here with more questions. You will have them.
Good luck
PS I sent you a PM
Now that was a truly useful reply and exactly the sort of information I am looking for. As noted I am "looking" at a coach. :):):)
Having RV issues? Connect with others who have been in your shoes.24,389 PostsLatest Activity: May 28, 2026
