Eco is missing on this Abs stage, you can set it 14,8 (or whatever it says in battery manual), but it lasts mere seconds unless you are watching it and changing settings on the controller manually. This is one of the things that I don't like about it, and there are few others. But you won't find anything both cheaper and better.
What do you mean here?
The eco and morningstar I read have adjustable parameters.
15A Morningstar model will exceed the limit occasionally , though unlikely will go up in smoke unless you are at high elevations. It might, but not likely.
I dont want something to go up in smoke..
Does my panel exceed the morningstars specs?
